[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 561: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 617: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 1065: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 1065: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 1065: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 370: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5284: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5284: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5284: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) TXL Fotos August 2018 - Seite 2 - Berlinspotter.de
Diese Seite wird durch Werbung unterstützt. Wenn Sie diesen Text sehen, werden die Werbebanner blockiert. Wie wäre es daher mit einer Spende, um die Website zu unterstützen?
Meine TOP10 von gestern, denn neben den Russen gab es auch noch anderes Fluggerät, das in meiner Sammlung fehlte ;-) Das Flimmern war dann insgesamt halbwegs verkraftbar.
Wow Christian und Digdis, Die Frontansicht und aber auch die Nachtaufnahme der il96 finde ich super, tolles Stimmungsbild. Welchen Standpunkt hättet ihr gewählt? Aber auch alle anderen Aufnahmen sind schön....danke fürs zeigen. Gruß Axel
@ Digdis, schönes Bild vom Samstagabend, hat Traumflieger recht. @Traumflieger, es war für die Frontale der 1,50 € Parkplatz neben der Busschleife am Kutschi, Ecke Nordlichtstrasse. Direkt an der Schranke... je nach seitlicher Windstärke ziehen sie da relativ gerade.
