[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 561: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 617: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 1065: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 1065: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 1065: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 113: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5284: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5284: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5284: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3903) Zwei Tage Amsterdam im September - Berlinspotter.de
9 Beiträge
• Seite 1 von 1
Im vergangenen September habe ich es endlich mal nach Amsterdam geschafft. Leider wehte der Wind so, dass die Flieger in dieser Zeit nicht auf der Polderbaan landeten sondern über diese die Starts abgefertigt wurden. Bei den startenden Maschinen hat man dann mit Gegenlicht zu kämpfen. Hier die Ausbeute vom ersten Tag:
Diese Seite wird durch Werbung unterstützt. Wenn Sie diesen Text sehen, werden die Werbebanner blockiert. Wie wäre es daher mit einer Spende, um die Website zu unterstützen?
Am zweiten Tag ging es zuerst in den Anflug an die Aalsmeerbaan.
Stellvertretend für einen der vielen Delta-Airbusse.
Für ein paar Starts ging es wieder zur Polderbaan.
Amsterdam ist auf alle Fälle eine Reise wert. Schade, dass KLM ihre 747 mittlerweile ausgeflottet hat. Auch die A310 fliegt nicht mehr bei Air Transat. Man kriegt auch einige Sonderbemalungen zu Gesicht, langweilig wird es dort eigentlich nicht.
KLM scheint es sich -noch- anders überlegt zu haben. Mit Überraschung habe ich vorhin die PH-BFT als KLM897 aus AMS nach Seoul rausgehen sehen, jetzt bei St.Petersburg...
Ja, früher wurden viele Combis als solche auch eingesetzt, bis Sicherheitsbedenken wegen des Feuerschutzes im Frachtraum bei einigen airlines zur Einstellung dieser Nutzung führten. Jetzt scheint man den besonderen Nutzen der Kombination wieder zu schätzen. Danke für den Link!
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
9 Beiträge
• Seite 1 von 1
